Jim Sanderson
One from a couple of weeks ago. The first round of grain was cut and the geese and cranes were gorging...........12 minute clip...
You might give that a try then, I have the headplus pro which has both tilt and pan and will hold twenty pounds. On a slider, the payload is 15 lbs and my set up for this was about eleven lbs.Thanks Jim, I see that a motorized version is $399. Not sure I am steady enough to pan manually.
