For those in the Astrophotography circles, you know that there is a subculture in Astro that has adopted the Samyang/Rokinon 135mm f2.0 lens for Astrophotography. There are several people that make 3D printed parts to cradle the 135mm in and provide a way to attach the ZWO EAF to it so it's an AF lens when connected to the ZWO ASIAir's.
I had bought the 135mm actually about 2 years ago on sale for Black Friday, and finally I bought the 3D kit maybe 6 months ago. Finally after quite a bit of procrastination, I assembled it all a few days ago. And so when there was a clear night at my Daughters house in Northern Colorado that evening I gave it a test on my ZWO AM5 mount along with my ASI2600mc Pro astro camera.
While the lens is a f2.0 lens, so it's fast, there are 2 sets of Astro Filters you can get. One for regular astro cameras that are about f4.0 and above and those that are faster like below f4.0. My telescope is f5.6 so all of my filters are for the slower lenses. So I set the Samyang at f4.0 to get a little speed but to still be able to use my filters, in this case the Antlia ALP-T 5nm filter.
I still got a lot of vignetting at f4.0, but I ran a Flat and Dark/Flat calibration frames for it. The Flats will remove the affects of the vignetting. It's Bortle 5 to 6 at my daughters house, so that's why I for sure need a filter to help with the light pollution. When I get back out to Joshua Tree NP in California in a few weeks, I might try the lens at f2.0 without any filter just to see what it looks like.
Anyway, the Spaghetti Nebula is really faint. I have captured it before with 10 minute exposures on my regular telescope with a reducer installed which takes the 500mm down to about 360mm. And at 360mm I was cutting off the edges of the nebula. So while doing a Mosaic is an option, I had been looking forward to trying it with the 135mm so I could get it all in with a single frame.
This has less then 5 hours integration, with it being so faint, this is one that really needs at least 10 to 12 hours, and perhaps as much as 20 hours of integration to really look good.
So this is unfinished, but I wanted to share at least the FOV that the 135mm provides. When I get a change later I will take a photo of the assembled 135mm.
38 Lights @ 300 secs with Antlia ALP-T filter
30 Flats
30 Dark Flats
30 Darks
ASI2600mc Pro - Astro Camera
Samyang 135mm - Scope
ZWO AM5 - Mount
ZWO EAF
ASIAir Plus - Astro Controller
Processed in Pixinsight
BlurXterminator
NoiseXterminator
StarXterminator
NarrowbandNormalization
Finished in Photoshop
30 Flats
30 Dark Flats
30 Darks
ZWO AM5 - Mount
ZWO EAF
BlurXterminator
NoiseXterminator
StarXterminator
