Time for Kayaking
This poor guy was pretty busy while camping with the grandkids at Windmill State Rec Area in Nebraska. But it did get a little break while everyone had lunch.
Photoshop Express on my iPhone I found is really softening the images when I downsize them for here. So this is a full rez image, not sure how it will look, but hopefully it still looks sharp.
Looks much sharper than the image you posted before - especially when you look at the tops of the trees in the background.
Thanks Alan. It had been itching the back of my brain for a bit that the images were being posted soft. But when I am on the road, it's hard to double check because I am just double checking on the iphone that I edited with. Back at my daughters house I could think and look a bit better.
I guess what I have to figure out is what's a good resolution for these iphone images to downsize to, that retain it's sharpness while still being smaller then the original.
No clue what settings you would want to use while doing edits on an iPhone. My peepers aren't anywhere near good enough to try to edit an image on my iPhone screen.
It's just general edits that I do on the iphone, so I am sure you could do it. You can zoom in to make sure it's sharp. Which is what I do. I would have thought Photoshop would have had a better down rezzing routine for the iphone app. There aren't any settings, you just pick the dimensions. I was using 1000 pix wide. But maybe I will try 3000 and 2000 wide and see how soft it gets, or if it stays sharper.
