On this one in White Sands National Moment last month the sun was getting lower in the sky, still about an hour before sunset I think, so I wanted to try a minimalistic image with the sun in the image. Hopefully this works out. I could with Shadow Recovery, completely recover the closest dune and show the ripples in it. But when I played around with that, I thought it lost some impact so I left it pretty much straight out of the camera.
It is 2 images, one for the sky and one for the ground where I used the finger over the sun trick to prevent lens flares. There actually was very little flaring with the 24-200mm Nikon lens, but there was a bit, and since I had shot it with 2 shots, it was way faster just to blend the 2 layers, that work on removing the lens flare itself.
