Orion & Running Man
Erik M
New Member
Thanks for the invite to join Jim Fox.
This is my Second attempt using iOptron Sky Guider Pro with iPolar. Although I had Tracker for few months could not get the first 2 iOptron Sky Guider Pro with iPolar to me to work. So I had very little practice. This is the first time I setup with my Nikon 300mm f/2.8, the first test were with a Nikon 24-70 F/2.8.
Getting more familiar with the SkyGuider Pro with iPolar. But need more practice. Any advise would be appreciated.
Nikon Z6 & Nikon 300mm F/2.8 G ED VR II & TC-1.4
I am still learning and my last post of picture was before I learned about Stretching data. This the results. What do you think?
M42 Orion
420mm 90 Sec. F/10 ISO 800
64 Light Frames & 36 Dark Frames Stack in Sequator & Processed in Light Room & Photoshop.
I had to fight the Moon that's why I was at F/10 instead of F/4. My front yard a good testing area I live in a Bottle Class 2 -3. So only Light Pollution is very minimal from 3 street lights out on the paved main roads. Still can't believe what I got.
Beautiful result - and welcome to Focal World. I am not an astronomical photographer but I love seeing the details in images like this one. Very nice work.
Welcome Erik! I am really glad you joined here. It's great to have a fellow SkyGuider Pro user on. :)
First let me say your end result is awesome! Really great work and it looked like you did a good job stretching. Have you tried DSS - DeepSkyStacker? That's what I am using to stack my images, though it looks like Sequator did a good job for you.
I might suggest shooting this at f5.6 instead of f10 and then lowering your ISO more. My last time out I actually shot Orion at ISO 64, and I had a different lens then you (Tamrom 150-600mm) so I was at f6.3. But, with that suggestion, you can't question your results as this sure looks nice! :)
That's great you live in such a dark area. It's too bad about the street lights, but still the dark skies sound great. I usually run out to Joshua Tree to do my DSO, and it's in about the same Bortle Range. I am heading out to Death Valley tomorrow to do some more Astro for a few days.
As far as the ioptron goes, my biggest suggest is to make sure you are setup right after sunset before it gets too dark. Since I also shoot landscape, I will usually shoot the sunset, and then immediately get the SkyGuider Pro setup and ready to go. Once I can start seeing Polaris in the sky, then I go to align it. I will already have my whole camera setup on the SkyGuider Pro and balanced, so when I do the polar alignment it won't shift at all by adding the gear after the alignment. If it gets fully dark, I can have a very hard time picking out Polaris through the iPolar. It's almost like finding a needle in the haystack since at that point all of the stars can seem equally bright. I have had to do it. A few times I have had the alignment drift off after 5 or 6 hours of imaging, so I had to go back and align it again, but in all of those cases, I could still see Polaris in the iPolar, I just had to make a few small adjustments to get it back to where it needed to be. I am using 2 apps, Polar Scope by iOptron and PS Align Pro to line up Polaris in iPolar. They will not be 100% the same, but I like to double check one against the other.
The one change I just made to my SkyGuider Pro was to get a new base for it. The one that comes with it works great, though when tightening it after aligning, you will see it can shift a bit, so when I tighten down the screws to lock it in place, I know mine always shifts down and to the left. So when using iPolar I line it up higher and to the right of where the Polar Scope app shows. I tighten it and make sure Polaris shifts into the right spot. This usually takes 3 or 4 tries, maybe 3 or 4 minutes to get it in the right spot.
So the new base. The main reason I got the new base, it's made by William Optics, is that I travel a lot, and I found that when I was in Colorado I couldn't adjust the stock base to a high enough Latitude with the base mount to get Polaris align. I actually had to cheat a bit by not having the tripod perfectly level, which obviously creates it's own issues. But I made it work. The William Optics base for the SkyGuider Pro will let me align it up with Polaris anywhere from California to Montana. :) Also, when tightening, it doesn't have really any drift. It's machined better then the base mount.
Very nice colors and details in this. I am also not into DSO photography but appreciate the results like this and the time and effort that goes into producing images like this.
And welcome to the forum.
Well, firstly, you must by lying, no one can be starting out is astroimaging with results like that! :D
Just kidding, but a SERIOUSLY awesome result, even more so for one of your first attempts. Jim has given you some great tips already and has direct experience with your setup which I do not have, as I am running much larger setups via computer control (actually remotely controlling the local computer with a remote computer) so my experience base is different at this point. I have shot lots of astro though so I know a good image when I see one. Your colors on this are very nice, and the framing is spot on as well, as the black level. There is often a tendency to make the sky too dark which not only can look unnatural (the night sky is NOT actually totally black) but which can lose some of the nice faint detail you have worked so hard to collect. I think you have a good balance between the 2 here with a very natural look. I would reiterate that you might wan to get some more light into your lens and bring that aperture down closer to f/2.8, although stopping down some does tend to mask any coma or other issues many camera lenses can have in the corners.
Really glad to have another FW member and a poster to the AP forum too! Welcome! I look forward to your many efforts in the future, keep up the good work!
