Solar Eclipse 2024 Gif
Here is a Gif I made of the Solar Eclipse in 2024 in Texas.
This is from the Seestar which has a narrow vertical pano sensor. There are about 30 frames in this gif, I did expand the canvas a bit on both sides so it wasn't so narrow, and on the frames where the flaring was cut off, I used Content Aware Fill to fill it in. It made up the difference in a way that looked pretty realistic to me. A few of the frames it didn't, so I had to spend extra time on those to get them looking good. Though, for as fast as the frame rate is for this gif, no one frame stays up long enough to actually examine how well or poorly I might have done.
I feel a bit squeemish about saying I had expanding the canvas and filled in the what was really a narrow strip. But doing it on both sides I think made for a more pleasing proportions. I don't typically add, or let Photoshop add things to my photos, but I wanted to try it and see. And since I did it, I might as well share it. So the ethics of it cause me a little pause, but I do make sure to say that the images are only 95% authentic. :)
Pretty good looking result although perhaps not for those who have issues with flashing imagery like this (I'm not one of them). I would not have noticed your canvas tweaks at all if it weren't for your backstory and even then I still can't really pick the nuances out.
This is very cool! My comment though is it would be much more powerful IMHO if you made it with slower transitions and a delay at the end, so that the viewer could really appreciate the actual flow in time from the beginning of what you captured to the end of what you captured. This rendition flashes though and then repeats so quickly it is hard to distinguish what is happening when and hard to appreciate the wonderful details you have here when they flash by so quickly. Slowing this down would also potentially alleviate the issue that Alan brings up as well.
As far as the extra added portions are concerned, I do not see anything glaringly obvious as far as artifacts, although again hard to say at this speed. I see nothing wrong with those type of edits as long as they are disclosed to the viewer as you have done here. The AI capabilities of the tools these days really allow for edits that were not possible before as I showed here: https://www.focalworld.com/threads/ai-ai-ai-or-yikes-this-worked-too-good.25706/
