Bushwhacking again
Got up early this morning to try my hand with a new set up. In order to save weight, I took my EOSM with adapter and 24-70 f2.8 which is not light. But the lens adapter combo is lighter than the 5DSR alone. I am also looking at a small tripod that folds to 12 inches and will fit in one of my Thank Tank holsters. To see if that was a good idea, I put my RRS tripod in that holster. The holster is 12 inches deep and a lot of tripod was sticking up. But it worked a lot better than last time with the tripod over my shoulder.
In fact, weight is not really the issue, but placement is. I could probably carry the 5DSR fine if the tripod was in the other holster.
But the EOSM acquitted itself fine, all 18mp.
I have about 7 more to process, and this is not the best. But I thought it good enough to post.
You got some neat water textures with this shot.
When I look at the specs I really don't buy into the notion that mirrorless is all that much lighter than my DSLR and my own adaptation is carrying my DSLR in a small over the shoulder bag with a single zoom lens - usually my 24-105mm. My tripod is already fairly light but with 3 piece legs it doesn't collapse down all that small to utilize something like my belt to carry it. One with a 4 piece leg would be a nice addition to my gear for lightweight hiking.
Hey Ben,
This looks great! You found a really cool spot here! The water really spreads out nicely.
I agree with Alan's point, there isn't much of a weight savings. In the end it seems the lenses designed for Mirrorless are very close in weight to their DSLR counterparts. You might save half a pound on the camera? The only way to save weight with mirrorless since all of us use Full Frame camera's is then to go to a crop sensor Mirrorless. My Sony A6400 is way lighter and smaller then my D850. At least half the weight and size since the crop format is so much lighter and smaller anyway, and if you use lenses designed for it since they are really tiny compared to Full Frame, that is where the savings is at.
I would venture to say for day time, well lit shots, the crop sensor mirrorless IQ would be really close to a full frame. The 2 ways that the crop sensors still lag behind full frame is Dynamic Range (DR) and Higher ISO Noise. So if you shoot during the day, usually those 2 elements don't become an issue.
As for a tripod, too bad about the 12" limit. Suriu makes some really great lightweight tripods, I have one that I love. It's about 16" though folded I think. ET-2004 is the Aluminum version, but they make the same one in Carbon Fiber.
Hey Jim, I agree with you, I did the math, a new Canon EOSR might save me 3 pounds, and partly because i would use a lighter 24-105 lens which I could also do with an SLR. Since I print, resolution also plays a roll. Also the EOSM is a real featherweight, but not going to be a main camera for me.
So you like Suriu? Good to hear, the one I listed is a 12 incher and carbon fiber. I meant grab in the sense that this is what grabbed my attention.
The EOSM has some really strong points. I would never have thought I would have a small mirrorless, but you know our camera's are tools and I have realized it's about having the right tool for the job. So for me when trail running, the small mirrorless is great. One of my hikes last summer where you are going from 8000 feet to 12,000 feet in Colorado I ended up just taking the Siriu, the Sony and it's 2 lenses. I would venture I saved probably close to 8lbs or more. Which when you are in those altitudes hiking trails that go almost straight up, to save almost 10 lbs of weight is huge in saving your legs and lungs.
I also will grab the Siriu when I am having to do a little rock climbing to get to some of the beach shots I go to when the higher tides cut off the beach. What's nice with the Siriu is it's still small enough I will take 1 leg of the tripod and slip it through my belt and let it hang alongside my leg. It works fine in a pinch to carry like that, if you can decipher my description.
I think I am going to hit the buy button Jim. The real issue was never folded length, but max length. I have a lot of trouble bending down as I am hunch backed and cant get my eyes back up to see the rear screen and controls. The EOSM has a rear touch screen and it made things much easier. My next camera will have a tilt screen too. ,
At this time, just the tripod. I think I can just carry the 5DSR and lens along with the tripod and it will weigh about the same as this morning. Like I said, getting the tripod off my back and cutting the weight did the job. Eventually I am going to get the Canon mirrorless replacement for the 5DSR and probably a 24-105 R series lens. That knocks off 5 pounds from my current kit. I don't do long hikes anyway, the bushwacking is usually under 1/2 mile, but in rough ground.
After a lot of research, this is the one I am looking at. This company has a lot of them, some cheaper some more expensive. The 12 inch folded length is the grab. Kinda short at 50 inches, but I can live with that.
https://www.amazon.com/AM-025K-Lightweight-Carbon-Travel-Tripod/dp/B07KD3YFC5
I like that little tripod. The weight savings aren't all that great (just over 1lb from the Gitzo Basalt I carry now) but the folded size difference would get the tripod off of my shoulders.
First off nice image Ben.
For my light weight tripod, I have a Benro which I bought, oh about 7 to 8 years ago. I folds to about 14" and weighs about 3.25lbs incl the ball head. It has served me well.
I do have the EOS R5 on my radar whenever that releases. Its not so much for weight savings as potentially better DR and features. With the set of lenses I carry, saving 2-3 lbs won't make much of a difference. For longer hikes I am good with a body and a 24-105 with a light tripod.
MonikaC
Glad you're continuing your adventures, Ben. I've always found that a pack that carries well can mitigate a lot of weight. I prefer to carry my tripod in a side pocket, rather than have its weight cantilevered off the back of a pack.
You are right, the Eos5 R i supposed to be 45mp, not much if a drop from 50. I only print yo 24x36 and 45 is probably fine. But what if they bring out a 100MP???
I am using a belt holster system for cameras and lens and hang my tripod over my shoulder in a sling. If hiking any distance, I have a Kelty pack that has water bottle pouches on each side and my tripod slips into the gap nicely and carry's very well. But when bush whacking, i don't like any weight on my back as I tend to fall over backwards when I get ensnared in debris.
MonikaC
Falling over backwards in not a good thing :eek:. Or forward or sideways, for that matter!
I did follow your suggestion this morning and went down hill facing the hill on all fours. Worked great
