Jim Sanderson
Still life from the dinning room table.
Thanks Jim, and everyone. This was one of my experiments. Was testing how my old Canon 180mm macro would work on the GFX100. Slight vignetting at the upper corners when rise applied. This was a focus stack of nine exposures at f/16, ISO 100 at 1/125s. Two lights, key to the upper right and an accent to the upper left at two stops less. Shot against a white background, I swapped the background for one of Adobe's paper textures. In the below redue, I added some canvas to the right side and cloned in the background to it and then re-cropped the image. I like this version a little better. Thanks again.This is so artistic! I agree with Alan, not sure if this is a photo, part painting or how you processed it, but I sure know that I like it!
Thanks for explaining the technique Jim, it's much appreciated. I hope you will be doing more of these type shots in the future.Thanks Jim, and everyone. This was one of my experiments. Was testing how my old Canon 180mm macro would work on the GFX100. Slight vignetting at the upper corners when rise applied. This was a focus stack of nine exposures at f/16, ISO 100 at 1/125s. Two lights, key to the upper right and an accent to the upper left at two stops less. Shot against a white background, I swapped the background for one of Adobe's paper textures. In the below redue, I added some canvas to the right side and cloned in the background to it and then re-cropped the image. I like this version a little better. Thanks again.
