Jeffrey
There are wide desert valleys between each of the mountain ridges seen here in the Mojave Desert. I wildly guess that this view is 25 miles long. Sometimes you don't see a view like this unless you are on a higher ground than the rest of the scene. Here, I was using my drone to extend the view by gaining elevation. And it's the first image using the secondary telephoto lens on my Mavic 3. That camera uses a smaller sensor than the main camera on the drone. It allowed me to reach out, as this scene was quite a distance off.
