Here is the final set of data from a very successful 2020 astroimaging campaign. 13 new images in a year, compared to 1 image from the period from June 2018 to March of 2020 - quite an improvement. I initially did not have great hopes for this data, as it was only collected as a NB bi-color data set, and the initial frames did not look all that impressive during collection. More proof to never give up on a data set until you have actually put some post processing time in on it.
The Lion Nebula is estimated to be between 10,000 - 12,000 light-years away, on the edge of the constellation Cepheus. A wider FOV or a camera rotator would have allowed me to get the entire nebula in view, but the resemblance is still visible in this rotated and cropped version I think. The 2x drizzle fortunately still left me with plenty of resolution to rotate 90 degrees and crop off the portion of the image that was empty, which orients the 'Lion' in a more favorable position to be recognized - can you see him?
This is an extensive emission nebula, which also has a distinctive 'searchlight' feature that appears to emanate from within the red region of this image, which is what initially prompted me to try for an image of this region. Lots of other interesting features that are also present however. The red areas are primarily due to ionized Hydrogen emission (Hα) and the Blue regions to OIII emission in this bicolor version.
As always, comments, questions and critiques always most welcome.
ZWO ASI1600MM-C Camera @ -20C and
Gain:200 Offset:50
Software Bisque MyT Mount
Stellarvue SVQ100 Astrograph Refractor, 580mm @ f/5.8
Innovations Foresight ONAG
Pixinsight Commercial Version 1.8
Innovations Foresight SkyGuard
Hα: 35 x 360 secs ( 3 hrs 30 mins)
OIII: 32 x 360 secs (3 hrs 12 mins)
Red: 13 x 30 secs (6 mins 30 secs)
Green: 14 x 30 secs (7 mins)
Blue: 11 x 30 secs (5 mins 30 secs)
7 hrs 01 mins total
10 x 60 secs, RGB (30 mins)
10 x 360 secs, Ha,OIII (2 hrs)
Bias Frames
Flat Frames
20 each filter
Gain:200 Offset:50
7 hrs 01 mins total
Bias Frames
Flat Frames
20 each filter
