Peridot Mesa, AZ
The hillsides look really nice with the blooms and all of the green. Best way to see the lower Sonoran deserts.
That saguaro doesn't look like it has a long life ahead between the top heavy branching and the weak spots on the lower trunk. Add in the weight of the extra water it's trying to store from the rains and it wouldn't take much for it to fall over.
That's funny, seems like a faulty system those cacti are employing if they fall over under their own weight :D Are there some external factors that cause the main trunk to weaken? Just old age?
There are a lot of ways any given saguaro might expire. The one in Doug's image isn't really old (maybe 60-100 years or so) but if you look carefully at the lower trunk there are signs of stress although it's not clear what the cause might have been. There appears to be damage to the trunk below the branch area. That area of the trunk also shows some necrotic tissue which would be the point of concern in this case.
As plants cacti store water whenever it arrives and you can usually tell how much water the area around the plant is getting by looking at the spacing between the pleats. This one has a fair amount of water in it but not enough to look truly bloated at maximum storage. It's not all that common for the deserts to get enough rain to start toppling weak plants because most of the rain comes from the summer monsoon season in the form of thunderstorms and the water drains rapidly in the desert soils. The plants take up what they can while they can since it might be weeks or months until any more arrives. Slow moving steady rain is not common or abundant but can happen in mid winter months and can set the stage for this wildflower show which also isn't a regular event. Seriously wet years can actually be hard on the cacti since they can take up enough water to the point of bloating and for specimens like this one that can be fatal given the weight of the top heavy branching. This specimen is a bit unusual for how many new branches are up so high from the primary branching point.
This is so cool Doug! I sure wouldn’t mind taking a trip there this spring. It’s got such a great carpet of flowers and that Saguaro really makes the shot.
You may be right about that Saguaro, Alan.
Sunny Sra
Douglas,
Beautiful colors and landscape. Poppy are starting to bloom around here now and it'll only be a matter of time. It may be a limited spring this year, we've already hit 85 degree days
