My winter project is to go through all my best images and find those that would make a nice 24x36 print. I have already winnowed it down to about 12, and many are not working. I thought I would share the lessons I am learning here.
First off, a 21-22 mpix image is marginal for 24x36 if there is much detail. The pixels per inch are around 150 and I find 200 to be a optimum for good results. This gets worse if cropping is required. So my oldest 21mpix images are from 2007 with the older images non starters.
Most of my existing prints are in a 16x9 aspect ratio and printed at 16.5 x 29 and I normally crop them in ACR so if later want a 2x3 aspect ratio (24x36) I need to start from scratch. That is not a problem because my processing is better now. But many of my favorite images don’t hold up uncropped because of composition.
You may wonder why I am locked into an aspect ratio. The reason is that frames cost an arm and a leg and I have a population of custom frames that are 16x29. I will only get one or two 24x36 frames made but I need to know in advance which sizes I am aiming for.
